Latest Programs: --- Renault CAN CLiP v187 [04.2019] --- BMW KSD2 Service Information [04.2019] --- Cummins INCAL - ECM Calibrations [04.2019] + (RMI) + (SIR) --- MAN Mantis v.606 EPC [03.2019] --- Toyota Industrial Equipment EPC v2.16 [02.2019] --- Caterpillar SIS 2019 DATA [01.2019] FULL --- Suzuki SDT-II Smart Diagnostic Tester v2.22.0103 [03.2019] --- BMW / MINI / ROLLS-ROYCE ETK [04.2019] --- Mitchell Estimating UltraMate v7.1.235 [03.2019] --- General Motors GMIO EPC Africa, Asia, Middle East [06.2018] --- Microcat Ford Europe [02.2019] --- Toyota Techstream v14.00.018 [02.2019] + ACTIVATION --- Scania Multi [1808] v18.50.1.2 [08.2018] --- Honda HDS 3.103.023 + ECU Rewrite [11.2018] FULL --- GT Motive GtEstimate DVD [01.2019] --- ODIS-E Flash files (Flashdaten) [01.2019] --- Renault Re-Prog CD v172 [11.2018] + Re-Prog Guide --- CarProg v9.31 + v8.21 + KEYGEN --- VAS-PC Flash Discs [01.2019] --- Renault PRE-CODE Calculator ---
Renault
Renault Diagnostic Tool.
[Image: t6f6mx.png]
[Image: ruw6co.jpg]
[Image: smaj4m.jpg]
[Image: 14lm0lv.jpg]
[Image: 2v34fu8.jpg]
[Image: b48gie.jpg]
Region: All Region
Language: English (Multilangual)
Version: v187
Developer: SPX
Platform: Windows7, WIN8, WIN10
Quantity of CD: 1 DVD DL
Year: 2019
Date of update: 04/2019
Renault CLIP - the latest diagnostic tool from Renault. It contains all the latest diagnostic technology and information base to address all issues.
Extras. Info: If the primary installation, follow the instructions, which is attached. If you already have an earlier version, it is recommended to uninstall and then follow the installation instructions.
It only works with original CLIP adapter or with a Chinese clone, no adapters and KL KKL is not supported.
Renault has developed a diagnosis system called Valise Clip. Hooked up to the car through OBD2 connector, it runs a complete test automatically, checking a series of parameters and identifying problems that can then be solved.
Program dealer car diagnostics Renault, Dacia, Samsung.
Starting with version CLIP 173, Windows XP is no longer compatible with CLIP.
[Image: 6rnijb.png]
Thanks given by: Zadokij , LindaGug , KorkaZ , Jefferyzew
selinofell197, Woodlenks788, 1 Guest(s)
