Latest Programs: --- Cummins INCAL - ECM Calibrations [04.2020] + (RMI) + (SIR) --- Perkins EST 2018A v1.0 [01.2018] + KEYGEN --- Subaru Select Monitor 4 v18.1.0 [07.2019] --- ODIS-E Flash files (Flashdaten) [11.2019] --- Caterpillar ET Electronic Technician 2019A v1.0 [01.2019] + ACTIVATION --- JCB ServiceMaster 4 v1.85.2 [03.2020] FULL --- Hyundai HCE e-Catalogue Robex [03.2017] --- JCB ServiceMaster 4 v1.81.2 [02.2020] FULL --- OP-COM Professional v.120309c [03.2012] --- Mitsubishi MUT-III PRE 20011-00 Diagnostic Software [2020] --- Chrysler ProQuest PAIS4 v4.5.0.2 [10.2014] --- Renault CAN CLiP v195 [03.2020] --- IVECO Power Truck + Bus Q1 [02.2019] --- BMW PSdZData v4.20.11 Lite [2019] --- Renault DDT2000 Diagnostic Tool DATABASE [12.2019] --- Mazda 6 Service Repair Manual + Wiring Diagram [2014-2019] --- Caterpillar Flash Files [07.2019] FULL --- Caterpillar SIS 2019 DATA [07.2019] FULL --- Renault Re-Prog CD v181 [10.2019] + Re-Prog Guide --- Honda HDS 3.103.048 + ECU Rewrite [2020] ---
Renault
Renault Diagnostic Tool.
[Image: 0.jpg]
[Image: 00.png]
[Image: 01.jpg]
[Image: 02.jpg]
[Image: 03.jpg]
[Image: 04.jpg]
[Image: 05.jpg]
[Image: 01.jpg]
Region: All Region
Language: English (Multilangual)
Version: v195
Developer: SPX
Platform: Windows7, WIN8, WIN10
Quantity of CD: 1 DVD DL
Year: 2020
Date of update: 03/2020
Renault CLIP - the latest diagnostic tool from Renault. It contains all the latest diagnostic technology and information base to address all issues.
Extras. Info: If the primary installation, follow the instructions, which is attached. If you already have an earlier version, it is recommended to uninstall and then follow the installation instructions.
It only works with original CLIP adapter or with a Chinese clone, no adapters and KL KKL is not supported.
Renault has developed a diagnosis system called Valise Clip. Hooked up to the car through OBD2 connector, it runs a complete test automatically, checking a series of parameters and identifying problems that can then be solved.
Program dealer car diagnostics Renault, Dacia, Samsung.
Starting with version CLIP 173, Windows XP is no longer compatible with CLIP.
Thanks given by: RidgeZecy , Brantlic , MarinaGOLot
