ACTIA Multi-Di@g v35.09A [III-2015]
Diagnostic tool
![[Image: 01.jpg]](https://i.postimg.cc/6qQNRZ4Q/01.jpg)
![[Image: 02.jpg]](https://i.postimg.cc/C17gz71t/02.jpg)
![[Image: 03.jpg]](https://i.postimg.cc/ydsK1tVc/03.jpg)
![[Image: 04.jpg]](https://i.postimg.cc/TPrGXfXT/04.jpg)
Ideal for the independent garage wanting a truly multi-make diagnostic tool giving in-depth diagnostics on a wide range of European-manufactured cars.
The Access kit is Windows-based, and can connect to any Windows PC or laptop with a USB port (subject to minimum specification).
Direct access to all diagnostics features
Diagnostic tool
Languages: English, German (MultiLang)
Type: Diagnostic tool
OS: WinXP, Vista, Windows7
Quantity of CD: 1 DVD
Year: 2015
Date of update: III/2015
License: High
With Multi-Diag, you don’t have to be an electronics expert. All features are just a few mouse clicks away via the intuitive, user-friendly interface.
Multi-Diag guides the operator step by step through the job ahead :servicing, wheels and suspension, brakes, air conditioning, anti-pollution, car body, and engine. The workshop mode lets you perform bull’s-eye diagnostics every time.
An expert mode providing advanced ECU diagnostics, physical measurements and configuration capabilities is also available.
MD_ReportAutomatic vehicle detection
As soon as you connect the OBD plug, Multi-Diag automatically identifies the vehicle* (no more manual data entry). Then, a mouse click takes you straight to the diagnostics page matching the make and model of the vehicle.
* Available on vehicles fitted with an EOBD socket.
BTN_express_diagThe Express Diag feature and Diagnostics Report
The Express Diag feature lets you run a comprehensive test across all ECUs in the vehicle in just 1 click. This feature lets you check the vehicle’s electronic status in a few minutes and then prints out a Diagnostics Report. This Diagnostics Report is automatically customisable with your workshop name and details, lists the ECUs tested and gives a detailed rundown of ALL errors identified.
